Gauge
How to use two needles in a numeric gauge...??can i control both needles at a time.??
Thanks in advance...
(2,966 Views)
Accepted by sks1990
Yes when you right click the gauge you will get an option called Add needle and in the BD your control will change to a cluster unbundle that and take the parameters. I would strongly recommend you to go through the basic tutorials in LabVIEW. Better go through the materials and play with LabVIEW.
(2,964 Views)
On right clicking all the controls(such as guage,thermometer etc:-) we can see a menu consisting of "properties".Clicking on properties a panel will appears and you can change whatever you want.
Thanks as kudos only:)
(2,958 Views)
Thank you..i have created it now.
(2,928 Views)
