Generate report using Word Report Generation VIs error
When I Generate report using Word Report Generation VIs  ,the error is generated.
This is  my Vi
can somebody  tell the error reason?
The attaché is Vi (one is 2011,other is 8.6)
Message 1 of 15
(5,445 Views)
probe 6 is error
Message 2 of 15
(5,435 Views)
Error 7 is a file not found error. Make sure the path to your template (and the template extension .doc or .dot or docx ...) is correct.
Ben64
Message 3 of 15
(5,426 Views)
I have  using this
 So the path to my template is relative path, and the template extension .doc is correct.
Can you run my Vi
Thank you!
Message 4 of 15
(5,422 Views)
When I ran it the template was not found (the template and the vi are in the same folder). I had to modify the relative path to this:
Ben64
Message 5 of 15
(5,416 Views)
I had modifyied the relative path to this:
But the error is apperaed:
probe 14 15 16 is error
Message 6 of 15
(5,405 Views)
Are you the Vi is coreect when you modified the  path ?
Can you pass me your run VI?
Message 7 of 15
(5,403 Views)
I can't run your code without error since my MS Word doesn't recognize chinese characters. What you are seeing is an error that was hidden by the first one (the file not found error). The error you are showing is after the Word Update Graph vi. To use this vi you first need to have a graph in your template, which is not the case, that's why you get an MS Word error message. You can use the Word Easy Graph vi instead.
Ben64
Message 8 of 15
(5,400 Views)
Hi Ben64
             Thank you! The problem is solved.
I want the Graph (curve),like as:13.jpg
How Can I do get the picture.
I have other problem. I want to get default name for the new word file.
liang
Message 9 of 15
(5,390 Views)
There is a graph type input to the vi. Right click on it, select create constant and change the value to the type of graph that you want.
Ben64
Message 10 of 15
(5,382 Views)
