How to run the exe in system tray?
dear ni,
                Interestingly i want to do something with labview with different task... now, after creating the exe is it possible to run on "system tray"
when exe window close that will come to system tray.... how to do this?,..
Balaji DP
(7,065 Views)
quick search
also see here
Message Edited by mathan on 11-11-2008 02:21 AM
(7,060 Views)
(7,013 Views)
thanks you,
                      i installed that activex.. but its support only with 8.x ..
do you have for 7.1 version?
in my system i have 8.5 and 7.1
Balaji DP
(6,992 Views)
This Inventeering toolkit allows you to create a LabVIEW program that can access the Window's System Tray. Now you can make your LabVIEW program show up with your custom icon, pop up tool tip, and pop up menu in the system tray. Comes with a Royalty Free built application distribution license.
Product Features:
PROGRAMMABLE loading of icons, tool tips and menus to the system tray that will allow your program to poll for system tray events; and then respond in accordance to your design needs. An example LabVIEW Program demonstrating use is also provided.
http://www.inventeering.com/_public/INVtray/INVtray.zip
INVtray
(4,980 Views)
