Generate single sine pulse waveform
Chan,
Have you measured across the AO and GND pins without the output on to see if there is an offset there?  There may be a problem with your card.  Also, what if you apply -3V offset to your output waveform?  Does the signal then look ok?  I realize that this is not an acceptable final solution.  I am just curious as to what would happen.  Maybe even try another output to see if you get the same results.  Let me know your results.
Lon
Message 21 of 26
(1,455 Views)
Hi Lon,
Below are the results for the measuremenrt:
Measure the AO channel without any output signal
AO 0
DC = 251 mV
AC = 0.4 mV
AO 1
DC = 251 mV
AC = 0.4 mV
What should i do? Is my PCI 6120 card, ok?
Generate waveform using 1000Hz with amplitude 4V and -4V
Please see the attachment for the result
When waveform generated using amplitude 4V, the waveform offset to the top.
When waveform generated using amplitude -4V, the waveform offset to the bottom.
What is the problem? Is the problem cause by the vi? I also attach my vi here.
Please advise me. Thank you.
Best wishes. Chan
Message 22 of 26
(1,446 Views)
When i tried with AO 1, the generated results are still the same with the results generated using AO 0. Thanks.
Best wishes. Chan
Message 23 of 26
(1,447 Views)
Hi Chan,
Could you try reading the AO voltage into one of the AI channels and see if you get the same behavior?
It almost looks like the scope that you are using is doing some offsetting based off of the initial measurement direction.  If you can confirm it with the same board, then I think that would help.
Message 24 of 26
(1,427 Views)
Thanks. Actually the measured value of the AO channel without any signal generated was done by a AI channel (with multimeter.vi). This offset behaviour only observed when 1 cycle sine waveform generated. No offset of the waveform when i generated continuous sine waveform. I wonder why? I need to solve the offset problem. Please do help me. Thank you.
Best wishes. Chan
Message 25 of 26
(1,421 Views)
Do you get the same behavior when you do 2 cycles?  1/2 a cycle?
I've never seen a board do that before, and cannot make mine act the way yours is.  Do you have a different board that you could test it with.  Any M, E, AO, or S Series board should be fine to attempt to replicate this behavior.
Message 26 of 26
(1,408 Views)
