 kooxy
			kooxy
			08-21-2018 04:22 AM
I'd like to generate a sinus with a usb 6001.
I've found this example but I can't get it to work!
Do you know what causes the problem?
thanks in advance.
Solved! Go to Solution.
			08-21-2018 04:37 AM - edited 08-21-2018 04:38 AM
08-21-2018 05:05 AM
I've just deleted the DAQmxStartTask and the error don't show up but the generation still dont work.
 PMH01
			PMH01
			08-21-2018 05:32 AM
Please give the task the time to generate your sine before stopping.
			08-21-2018 05:37 AM
08-21-2018 05:41 AM
It works perfectly !
Thank you very much
Solution :
