Generate sinus via USB 6001
I'd like to generate a sinus with a usb 6001.
I've found this example but I can't get it to work!
Do you know what causes the problem?
thanks in advance.
(3,793 Views)
Ho kooxy,
when you enable Autostart at DAQmxWrite you don't need to call DAQmxStartTask later on…
Did you read the error explanation?
(3,790 Views)
I've just deleted the DAQmxStartTask and the error don't  show up but the generation still dont work.
(3,778 Views)
Please give the task the time to generate your sine before stopping.
(3,772 Views)
Accepted by topic author kooxy
Hi kooxy,
there is a DAQmxWaitUntilDone function - use it!
(3,769 Views)
It works perfectly !
Thank you very much
Solution :
(3,766 Views)
