Generate specific pulse
I have an NI9401 module with cDAQ-9178, I would like to use it to control my multiplexer. I would like to manually select a specific channel and let stay on, for example in the front panel, I have a button to select channel 3, it will generate 3 pulses and stay on at channel 3, if I select channel 5, it generates 5 pulses and stay on at channel 5. I greatly appreciate if someone can share some ideas and provide a sample code.
(2,833 Views)
Hi Xiao,
Which "channel" do you want to select?
Are you talking about channels of your NI9401 - or of your "multiplexer"?
Where do you want to output those pulses?
What means to "stay on"?
What happens with "channel 3 stay on" once you select channel 5?
So many questions, so little information…
(2,790 Views)
