Generate triangular signal with ramp signal.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 11 of 18
(1,104 Views)
sampling period; (control) is points/period?
What is this block?
Can this block be replaced with something like +, -, x or something else?
In the second if loop, what is in the 2nd position of Positive? Can you give me a screenshot?
Message 12 of 18
(1,096 Views)
I would probably use significantly less code:
Yes, you need to think about edge effects. For example since the max and zero should not duplicate, you need to decide how to treat things. Tweak as needed.
Note that you must make an effort to understand every subtlety of the code (e.g. the concatenating tunnel and the special mode for "built array", etc.) and be able to explain it to the teacher. The teacher reads this forum too!
Message 13 of 18
(1,086 Views)
mihairusu11@yahoo.com wrote:
What is this block?
The picture is actually a LabVIEW snippet, so just download it and then drop it onto your diagram and all code will be there! (see also here for details)
Message 14 of 18
(1,085 Views)
If you want to terminate the train with the first point, here's how you could modify the code (this is NOT a snippet!)
Message 15 of 18
(1,079 Views)
I want the scheme to be as simple as possible, as is the scheme above but without the block with "i" and "rq".That is, it should be with the most fundamental things, more mathematical calculations, based on formulas.
Message 16 of 18
(1,023 Views)
Can you give me both situations in the second case and tell me if there is any situation in the first case?
Message 17 of 18
(1,006 Views)
You probably mean "r" and "iq", a simple quotient and remainder function. A fundamental function.
As has been said already, the picture is a snippet, so you can just drop it on the diagram and it will turn into functional code where you can look at the other cases.
Have you looked at my earlier example. It is very simple!
Message 18 of 18
(993 Views)
