Generating a Code39
I am working on a project to create a Code39, I am done with the most part I believe, however I'm facing a problem with implementing my array into the code to get a different barcode each time. If anyone can help I'll be thankful.
Message 1 of 16
(3,309 Views)
Save it for LV 2021 and I'll take a look at it.
Message 2 of 16
(3,300 Views)
I don't know the details of code 39. can you explain the process in order us to help you ? Where do you think is the problem with your code ?
Message 3 of 16
(3,248 Views)
I saved it to the previous version
Message 4 of 16
(3,244 Views)
I am trying to make my code change the number of triangles to be printed depending on the specified Narrow wide specifications, also giving that the ratio of narrow to wide is 1:3.
Message 5 of 16
(3,242 Views)
That's still the LV 2023 version.
I'm stuck at LV 2021.
Message 6 of 16
(3,205 Views)
Version 21.0 should work I converted it again
Message 7 of 16
(3,166 Views)
Characteristics of Code 39:
it consists of bars (black lines)/spaces (white lines) of two widths (use 1:3 proportion of narrow-to-wide in your VI)
allows to encode 43 characters: A÷Z, 0÷9, and -, ., $, /, +, %, space anda special symbol marked with an asterisk (*)
each character consists of 5 bars and 4 spaces, from which 3 bars/spaces are wide,and 6 bars/spaces are narrow
in each character,the bars and spaces are placed alternately, starting with a bar
a narrow space is used between each character of the code
the first and the last character must be the special symbol (*)
Those are the characteristics I am trying to implement, I am facing problems with the first two right now
Message 8 of 16
(3,156 Views)
This is 2020 version
Message 9 of 16
(3,153 Views)
Your code is messy.  Zero effort at clean coding.  That's a big turnoff.
I'll look at it later.  Maybe.
Message 10 of 16
(3,145 Views)
