Generating a flicker signal VI?
Hello all,
I'm currently creating a program which creates several tests concerning Power Quality with a Daqmx PXI-4461.
First of all i would like to say that i have no problem generating or reading signals with the Daqmx.
I'm currently at the point where I want to generate a flickering squarewave signal (flickering = small voltage dips over time) with the Daqmx, and was wondering if there was an example somewhere on the web that lets me insert the flickerfrequency and % decrease compared to the RMS value
Like a good professor of mine always said, its better to edit an excisting example then to start from scratch!
Dennis
(2,584 Views)
Hello Dennis
I didn't directly find directly usable code, but I did find something else:
https://forums.ni.com/t5/Student-Projects/Power-System-Flicker-Emulator-and-Measurement-System/ta-p/...
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(2,539 Views)
