can I convert data in a *.td file to ascii?
I have a *.TD file and have recived a requrest to have the data converted to ascii.
Can I do that? If so, how?
(2,664 Views)
Hello Isenhand,
What type of file is this file with .td File extension?
Is it a Borland Debugger Configuration File ?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(2,625 Views)
