Generating a report tracking vi usage
Hello, I'm very much a beginner in labview and I need to be able to compile a report that tracks essentially when everything happens in my vi and what the variables are. So when the start button is pressed, what all the drop downs are set to, when each of the pop up vis show up, what all the variables in those front panels are set to, any rerrors that show up anywhere, and when the whole loop finishes running. And it's meant to be a cohesive table that is trackable, and I just have no idea where to start. The quick reports built into labview make it all one large text file and include lots of the background variables that I do not need. Is there an example vi I could use that tracks these aspects that I could use as a basis?
Thank you very much.
Message 1 of 1
(682 Views)
