Generating events at random hours
Hello All,
I am testing a pressure system and would like to turn on a valve for x number of minutes at y hours, where both x and y are random number. How does one generate a event that lasts for a random number of minutes at random hours?
Thanks in advance,
KB
(3,532 Views)
There are plenty of ways to do this. If you like to use an event structure, you can use the timeout event initialized with a suitable random variable for each iteration to switch the valve. The attached example turns the valve on for a random amount of time in the range 2-4s and then off for a random time of 6-12s.
(3,532 Views)
(One little dataflow flaw in the code. The "get time/date string" must be forced to execute after the event strucure, else the log times are off.)
(3,532 Views)
Works well. I am modifying the vi to send a digital pulse to the valve and so on. But how do I change it so that the valve remains open for X MINUTES and waits for Y HOURS (x and y are random). The way you have it the X and the Y are derived from the same random value, right?
Thanks for your help. I noticed that you have answered my previous questions as well!
(3,532 Views)
The event structure acts as a toggle. The timeout value is randomly generated by the case structure in front of it and the case depends on the current state of the valve. The 0-1 random value is scaled and offset differently for the two cases. Simply scale the ON case to get e.g. a random number of 60000 to 660000 (1-11 minutes) (RND#*600000+60000) until it turns from on to off and a much longer timeout (hours) to turn from off to on.
(3,532 Views)
