I have a PCI 6013 and I have made a DAQ Assistant to read in two voltage signals, but the DAQ Assistant only has one wire coming from the output, how do I split that wire so I can see the two different outputs?
Using a PCI-6013 to read in two voltage signals I would like to know how to read out two seperate wires that show one of the signals in each wire.
(2,696 Views)
