error in create file iak of field point explorer
I've field point explorer 3.0.1 , labview 6.0, when I configure a new file iak all is ok & i read with field point exp. all module(PC1);when I try with labview I've the error 33162 "unable to connect to the data module".
The same vi & same configuration of field point explorer function in another PC2.
When I take the file.iak in the PC2 ok and I copy this in PC1, labview in PC1 function without error.
It's possible to create a new file in PC2 and then copy in PC1 or there is another solution?
(2,546 Views)
MicheleCS,
Yes, it is possible to create a new IAK file on your second computer and then copy it to your first computer. You shouldn't have any issue with that at all.
Regarding your error code 33162 here is a Knowledge Base that explains the error:
http://digital.ni.com/public.nsf/websearch/C4E77D7E9BECBAFE86256C6200544289?OpenDocument
Ames
Applications Engineering
(2,546 Views)
