How to get I/O on one port
I need to supply a chip select signal,40KHz clock,DI and DO on one port of the NI-6534 DAQ.
Can it be done, and how?
(2,521 Views)
Unfortunately, I do not know of any way that you can do this using only one port. The problem is that you will need to use a strobed operation for outputting a digital signal. The 653x devices do not have the ability to input and output at the same time during using a strobed operation. However this can be done if you could use port 0 and 1 as input and port 2 and 3 as output.
Let us know if you would like more information on how you could do this using two ports.
Justin T.
(2,520 Views)
