Generating of QR code in offline mode
Hello everyone. I want help to generate QR code in the offline mode. I did
try to generate QR code using labview but when am online. i am able to generate
the qr code. I will attach my VI below for the online.
Can some1 help me please.
(5,078 Views)
Accepted by Zahkay
(5,066 Views)
Thank you very much
but it is hard to understand the icon they use to make it.
I check the all the link that you send me and all the link that link to it
when i am checking the VI, i can run the VI but to understand it is
difficult. can you please help me with that
(5,044 Views)
If you really, really understand LabVIEW, you could probably learn the mathematics of Finite Fields that is going on.
If you really, really understand Finite Field mathematics you could probably learn the LabVIEW that is going on.
If you are new to LabVIEW and do not know what a Galois field is, then it will be very hard to provide a terse explanation.
Hopefully it works for you and over time you can figure it out, but I would not suggest using that as a vehicle to learn LV or to learn Finite Field math.
(5,021 Views)
Hello again sir
Yeah i am new in labview and with the specific term you used make me like i have to check it out.
i will try my best to understand.
Thank you very much
In case you find easier and more direct Vi, i will grateful to hear from you
Regards
(5,003 Views)
@Zahkay wrote:
Hello again sir
Thank you very much
Regards
This is one of those times that you just say thank you and keep learning.
There is nothing "Basic" in that code. not the code and not the math.  And the correct honorific in this case would be "Doctor"  As in "more degrees than most thermometers" (Not that he doesn't play with large numbers of negative degrees that don't appear on most thermometers)
The strange thing is he probably coded that up "just for fun"  Some days his examples just make me want to go play with a frisbee.
(4,987 Views)
hello darin
your program is very useful. thank you for this
despite of this, I have noticed a kind of bug: when the qrcode is big (version>around 17), sometimes, depending on the data, the QR is not detected.
the more I increase the correction error level, the more often there is unreadables qrcode.
take a look in the picture joined. this QR has been done with version 21 and correction Q (but unreadable qrcodes appear also at level 16 and correction L)
Pierre FCentum TNS, Grenoble
Certified LabVIEW Associated Developer
(4,441 Views)
