Generating signal as shown in the image in labview
Is there a way of changing the vi so that it can detect the red lined(signal) in the image because i got this image from a report which has a red waveform.I don't know hwo to change it to red.
Message 31 of 34
(870 Views)
can someone help me out in modifying the vi attached in my last post to make it work with the red line image as now it is working with only white line in the image.
Message 32 of 34
(853 Views)
Is there someone that can help me out in modifying the attached vi so that it will work with the detection of the red lined(signal) image(attached as notworking image) as it is currently working with the white lined(signal) image(attached as working image) .
or is there any other alternative to change the red line in the image to white line.
Message 33 of 34
(834 Views)
How about using a 4 bit pixmap. The "colors" output is a list of 16 colors. The pixmap is a 2d array of those color numbers. Colors 3 and 10 catch most of the waveform.
Message 34 of 34
(821 Views)
