Generating voltage output signal, like an oscillator.
My task is to create a VI to simulate an oscillator with an output of 1-100 HZ on either the digital or analog outputs. I am able to generate a voltage signal through the DAQ Assistant and when connected to an oscilloscope, the output signal is acquired and displayed. My issue is being able to control the signal type and frequency from the front panel. Please help!
(2,540 Views)
Have you looked at the shipped examples provided with LabVIEW (Help -> Find Examples). If you are not able to find an example, post whatever you have done up till now and we should be able to help you.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,531 Views)
I want to use controls for the output voltage, frequency, and wave type. Here is what I have
(2,509 Views)
