What is the difference between daqmx daqmxbase??
So whats the difference?  The descriptions in the Help are identical.  If you didn't look at the label ( using help) you wouldn't be able to tell the difference between the two.  When do you use one over the other??
(2,770 Views)
Accepted by topic author clint100
Have you looked at the readme?
(2,768 Views)
Thanks!!  I will read thru it.
(2,756 Views)
