Generic Project Error
What rocket scientist thought this would be a useful error message?
Message 1 of 9
(5,071 Views)
When those pesky bugs keep showing up and you aren't sure what's causing them or how to fix them, it's more "professional" to show a generic error message that means nothing than to let the program crash and burn.
Smiley Very Happy
aputman
Message 2 of 9
(5,051 Views)
Too emotionally insecure to call it an "unknown" error!  😄
Bill
CLD
(Mid-Level minion.)
Message 3 of 9
(5,032 Views)
Well, it just states that your project is too generic for LabVIEW... Smiley LOL
Message 4 of 9
(5,019 Views)
Hi paul_cardinale,
Generic errors are used because it is very hard to foresee every possible issue users may encounter while using LabVIEW. There are nearly infinite possible architecture options when creating a VI.
If you can provide some details about your code and when this error is occurring, I may be able to help diagnose the issue.
 Jared T.
 Applications Engineer
Message 5 of 9
(4,985 Views)
I have a project that contains several classes.  A number of the classes are child classes, some of them nested 3 deep.
I changed the name of a dynamic dispatch acsessor VI.  For some of the VIs, Save as,,, worked OK; but for a couple of them I had trouble, so I tried deleting them then adding them back.  It was when I tried adding a file to a class that the error occurred.  The next day I tried again and it worked OK.
Message 6 of 9
(4,967 Views)
When I create code, if it's reasonable, I try to make it generic (I like reusability).  I guess I just went too far.
Message 7 of 9
(4,966 Views)
Spoiler
After reading your posts over the years I have to ask "Is there any question that you went too far?".
Ben
Message 8 of 9
(4,961 Views)
I like to try pushing every button I find.
Message 9 of 9
(4,939 Views)
