Genuine compass indicator
Am am looking at ways of showing a compass indicator where the dial moves, not the needle.  As in to display how a real compass behaves in an vehicle where the meter is floating?
Message 1 of 11
(13,928 Views)
Have you gone through this thread
Message 2 of 11
(13,925 Views)
Yes I have searched the forum fully.  All of the previous examples involve the needle moving around the dial i.e. the top is always north.
I am looking to move the dial around the needle i.e. the direction you are going is always at the top
Message 3 of 11
(13,921 Views)
Change the property node for Scale.ScalePosition.Start for the dial.
Message 4 of 11
(13,918 Views)
I'm a relative newbie.  While I can get a property node... I can't see how it integrates with the guage in the VI: so I cant test it yet.  Could someone please suggest an example/resource on the use of property nodes (which look really interesting thanks).
Message 5 of 11
(13,903 Views)
Do you want something like this?
Message Edited by Baji on 09-14-2009 11:47 AM
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 6 of 11
(13,890 Views)
Accepted by DTA
No.  They are the wrong property nodes.
Like this.
Message Edited by Ravens Fan on 09-14-2009 10:41 AM
Message 7 of 11
(13,839 Views)
I went a few steps more and added text labels to the directions
Message 8 of 11
(13,811 Views)
Thanks.  I presume the same methodology would work to make 'linear' meters.  Where the scale would move up and down the pointer (similar to a slider but the slider stays central and the scale moves).
Message 9 of 11
(13,806 Views)
hey mf  u can  upload  the  file  en .vi complet  about  your compass plzzz
Message 10 of 11
(11,956 Views)
