Get Array Element reference
Hi all,
There some problem with array property - Array Element. This property always get reference to active element of array, so you want to get in loop references of all array elements you can't do it by simple way.
I know some trick how to do it: by changing Array Property IndexValues you change Active Element. But the problem that this method change GUI.
My question is there another method to do it?
(5,962 Views)
If I understand what you mean, you need to get the references of all the element of an array, correct ?
Why Smiley Surprised ?
As far as I know, if you change a property of an element in an array, the same change will be applied to all the elements of the array, appart of course for the value Smiley Wink.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(5,955 Views)
Hi TiTou,
i need to operate with array of clusters and i don't know actually type of cluster, but i have some VI that get me all data about cluster, what values in each cluster element, what type,.... So i need to get reference of each array element for this VI
(5,947 Views)
Well... I think you have to go with the tip you described... getting the size, a for loop to set each element one by one... the problem is that this will be quite slow... Smiley Indifferent
Sorry no idea on how to improve that... Smiley Sad
Epictetus
Antoine Chalons
(5,943 Views)
Take a look at the attached image (too big to imbed in the post) to get an idea on how to manipulate an array of cluster using references.
Titou is absolutely right about this method being sloooowwww Smiley Very Happy
Hope this helps...
cheers
David
(5,939 Views)
In fact, I was wondering if there was another method using OpenG Variant Lib... Smiley Surprised
But I´m not used to play with variant and I was expecting somebody more experienced to come up with a better idea.
That reminds me of the "escalate" button Ben was talking about in the breakpoint board 😉
Epictetus
Antoine Chalons
(5,931 Views)
