change user-interface priority
Hello LabVIEWERS ,
Does anyone of you know how to set/adjust the user-interface priority of a
LabVIEW program.
In an certain application I noticed a bad respons from LabVIEW towards the
user-interface
(it reacts only very slowly towards pushing a button or for instance
dragging the LabVIEW frontpanel)
although the processor utilisation is only a few percent. I don't want to
put delays in the code unneccesary.
I tried to lower the execution priority of LabVIEW but I don't see any
difference.
I use windows2000 as platform and LabVIEW 7.1 if that matters.
René Ramekers
(2,971 Views)
hi there
in almost all cases the reason for slow gui response is NOT the priority of the vi. there are a lot of reasons:
- (hidden) delays (e.g. reading from an interface using a timeout)
- lot of memory/disk access
- lot of data to show on the gui
- unneccessary repitions of function/vi calls
- (very) poor graphic hardware
do you use event based programming and a high level/low level architecture in your application?
i think best would be to post some code here, so we can have a look at it. like i said, there are a lot of possible reasons...
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(2,964 Views)
Thanks for you suggestions, but I already found it myself:
it appeared to be a DLL which was called very often ,
and this DLL was running in UI - thread. Changing it to "reentrant" did the
trick .
René Ramekers
"chrisger" <x@no.email> wrote in message
news:1156255808695-407091@exchange.ni.com...
> hi there
> - (hidden)&nbsp;delays (e.g. reading from an interface using a timeout)-
lot of memory/disk access- lot of data to show on the gui- unneccessary
repitions of function/vi calls - (very) poor graphic hardware
> do you use&nbsp;event based programming and a high level/low level
> &nbsp;
> &nbsp;
> &nbsp;
(2,950 Views)
