Get Date/Time String equivalent in NXG
I have a Vi on LV 2017 that uses the regular Get Date/Time String vi that receives an integer.
I couldn't find the equivalent on LabVIEW NXG, there are several choices but not of them output the right string that LV 2017 outputs
CLAD, CTD
Message 1 of 10
(4,990 Views)
Is there something corrupt in your LabVIEW installation?
On mine, that isn't an integer, but a timestamp.
 Capture
EDIT:  Perhaps nothing is corrupt in your LabVIEW installation.  That might be a polymorphic function.  When I wired an integer into that same terminal, it connected without a coercion dot and the context help changed to look like you have it with a blue wire going in.
I have not touched NXG at all.  But have you tried to wire in your integer into the function it provides?  At the end of the day, the function is looking for a number that represents seconds since the epoch.  If your integer can't wire directly to the existing function without error, perhaps you can adapt the date from an integer to whatever the function will take?
Message 2 of 10
(4,962 Views)
It looks like 'Get Date and Time String' in NXG doesn't have a polymorphic 'timestamp' input like it does in LabVIEW. So you'll need to insert a 'To Timestamp' function in NXG to get the same behavior:
Message 3 of 10
(4,951 Views)
I will try that tomorrow...
I remember i tried that but it was an interger, not a double...
Going to double check tomorrow....
CLAD, CTD
Message 4 of 10
(4,925 Views)
Did not work...
Look at the picture...
CLAD, CTD
Message 5 of 10
(4,902 Views)
Help for Get Date/Time String (LabVIEW2015):
"time stamp can be a timestamp or a numeric. If numeric, this number is the time-zone-independent number of seconds that have elapsed since 12:00 a.m., Friday, January 1, 1904, Universal Time [01-01-1904 00:00:00]. The default is the current date and time. If year is before 1904, time stamp is negative."
This is no solution to your problem but, I would say LabVIEW2017 is doing something wrong with the negative number and NXG returns a more logic result. -703196896 seconds are a bit more than 22 years before 1904.
Edit: Sorry, the result from Get Date/Time String is not logic at all (12/31/1903). I confused with date time record.
Message 6 of 10
(4,890 Views)
the problem is with just that specific function:
(image taken from LV2011)
I do prefer FormatIntoString most of the time (for any kind of string handling)…
Message 7 of 10
(4,883 Views)
So did i find a bug or what?
CLAD, CTD
Message 8 of 10
(4,873 Views)
There’s definitely a difference in behavior, but I hesitate to call it a bug, since sending a negative integer into a time stamp parameter doesn’t appear to me to have defined behavior.
Message 9 of 10
(4,854 Views)
I think it is more than an inconsistency.   Possibly a bug on the integer version of Get Date/Time String in traditional LabVIEW.  (See the attached snippet.)
There is a defined behavior for negative values in timestamps.  It is that they reflect the number of seconds BEFORE the epoch.  The NXG version of Date/Time record is handling that.  The NXG version of Get Date/Time String seems to be coercing it to 0, and thus the epoch.
Classic LabVIEW with a negative value going into a timestamp indicator is giving the same date time as the NXG date/time record.  But the negative value going into Get Date/Time string is being typecast into a U32 then that being given out a string.  (So 2's complement of -703196896 is 3591770400.)   There is no coercion dot happening on that input indicating that anything different is happening.
I have a question for the original poster:
Why are you dealing with negative integers in your timestamp values?  It is not impossible, but very unlikely you'd be doing anything with timestamps for the 1880's.
Does the date Oct. 25, 2017 mean something in your data more so than  Sept. 17, 1881?  I bet, without seeing your code, that you have an issue with your data types upstream.  If you fix that, the issue with your timestamps in the Get Date/Time String will resolve itself.
 Example_VI
Message 10 of 10
(4,846 Views)
