Get Information From File Name
I have a somewhat general question, is it possible to extract certain "elements" from a file name?
For example: x0 xxx abc 123 xx xxxx.avi (or any type txt, jpg, and etc...).
Assuming that the "abc" is constant throughout the files but the digits are changing (not sequential), can I extract just the "abc 123" (or whatever number it is)?
I know how to strip/build path, but here I don't know what to search since the distance from the beginning is changing and the digits are changing.
Thank you,
(3,740 Views)
There are several string function that allow you to search for a string, and  break the string into several parts.
Another option is using Regular Expression, yours sound like "abc/s[0-9]{3}", that should return the "abc 123" part.
Ton
My LabVIEW Ideas
(3,727 Views)
Accepted by simply_me
There are dedicated search functions for strings that you should investigate. This is a basic LabVIEW task.
23472iD8C9D52B59B88F37
Chilly Charly    (aka CC)
(3,721 Views)
Hi Ton,
lurking the forums before breakfast ? 😄
(3,719 Views)
Thank you both for the reply.
(3,708 Views)
