Get .NET array from Object
I have .net library that returns data as System.Object that is really a byte array ("The pixel data buffer is provided as a byte array for a grab result"). I want to get them as LabVIEW array.
Width and Height return image size, they work fine, so I have image data.
In C# it is done as following:
// Access the image data.
Console.WriteLine("SizeX: {0}", grabResult.Width);
Console.WriteLine("SizeY: {0}", grabResult.Height);
byte[] buffer = grabResult.PixelData as byte[];
Console.WriteLine("Gray value of first pixel: {0}", buffer[0]);
It is Basler USB camera through their Pylon. I do not have NI vision.
Thanks for help!
(3,644 Views)
Accepted by Alexander_Sobolev
Problem solved.
Simply .Net object to variant.vi from .net palette.
(3,612 Views)
I have the same question.
Thanks for your help
(3,501 Views)
