Get OUTPUT and RETURN parameters from a stored procedure
I have a stored procedure (MS SQL Server 2008 R2) like the following example.
Using Database Connectivity I can get the OUTPUT parameters but I can't get de RECORDSET DATA and de RETURN value.
Does anybody knows how to do that?
CREATE PROCEDURE [dbo].[TS_Teste] (@T057_S_NOMEMAQUINA VARCHAR(20), @STATUS INT OUTPUT, @ERRO NVARCHAR(500) OUTPUT)
AS
BEGIN
  DECLARE @TABLE TABLE(CODIGO INT, DESCRICAO VARCHAR(30))
  INSERT INTO @TABLE VALUES (51, 'A')
  INSERT INTO @TABLE VALUES (52, 'B')
  INSERT INTO @TABLE VALUES (53, 'C')
  SELECT * FROM @TABLE
  SET @STATUS = 1
  SET @ERRO = 'Nenhum erro!'
  RETURN 0
END
(3,549 Views)
Now I could get the RETURN, but I still can't get the RECORDSET DATA (returns empty but shouldn't be). Please anybody help me.
(3,542 Views)
Accepted by topic author fabian.oberdiek
I finaly found what was wrong... It was necessary an only aditional line in the stored procedure. It should be like that:
AS
BEGIN
  SET NOCOUNT ON;        -- NEW LINE!!!
  SET @STATUS = 1
  RETURN 0
END
(3,529 Views)
