Retrieve and short mysql database
Hi experts, i have build a simple program and record the data to mysql database. Now i want to retrieve the table data and i add a combo box as a filter for when displaying data. is it possible to do with database connectivity toolkit? please see attachment
Thank you
(2,984 Views)
Hi Ijan,
You can use database toolkits to retrieve the data from the database.
Find some examples related with database in Help-Find Examples-search-database.
You can directly call your table or you can fire a query to fetch the data.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(2,978 Views)
Select Column1,Column2,Column3 from Table order by Column1,Column3;
Use Database toolkit to get column names and populate the combo boxes and an event to rerun the SQL-query whenever one of them changes. It shouldn't be too hard.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,971 Views)
