Traditional daq LV 2010
Hi all,
I'm using LV 2010 in Win XP.  I have a PXI 4351 installed which requires traditional DAQ.
As I didn't see any traditional DAQ vi's in LV although I saw the 4351 in MAX and was able to use it there.  I looked around in the forum and the knowledgebase and found out that I had to remove and re-install the traditional DAQ if I upgraded to a new version of LV (which I had done).  Unfortunately, the problem remains ... .
Any other solutions ?
Jan
(2,193 Views)
Did you install the correct version? You need 7.4.4 (http://joule.ni.com/nidu/cds/view/p/id/570/lang/en). During installation was LabVIEW support selected? Also, what problem are you referring to?
(2,184 Views)
