Get Recently Modified Files
I need to create a list of recently modified files from a given folder on local net.  The folder contains thousands of files in hundreds subfolders.
The conventional method (attached) take way too long.  ~40 secs in office, > 5 min at home (with VPN).
I can do better with command prompt.  ~20 secs in office
Window Explorer (manually) can do it in ~5 sec  in office,  < 20 sec at home.
Anyone got a better solution ?
George Zou
Message 1 of 9
(6,858 Views)
I don't know if it's better, but here's .NET solution:
It's about 3x faster than native LabVIEW on my machine (listing files using DirectoryInfo rather than native Recursive File List.vi looks much more efficient). I didn't test it thoroughly, so you might want to play a bit with FileInfo properties (there are UTC versions of timestamps). Or you might just get file name from FileInfo and then native File/Directory Info as in your code.
Here's documentation on DirectoryInfo class: https://msdn.microsoft.com/en-us/library/system.io.directoryinfo_methods(v=vs.110).aspx
Message 2 of 9
(6,807 Views)
Thanks.
It's much faster to use .net to retrieve files.  19 sec.
George Zou
Message 3 of 9
(6,792 Views)
~60 sec at home.
George Zou
Message 4 of 9
(6,786 Views)
I know it's a quickie (and that OP and you know this), but close those refs!
It will leak memory (at 10 MB\sec. on my PC) when used in production code if you don't.
Message 5 of 9
(6,763 Views)
Accepted by zou
Have you tried with the System Exec.vi?
Ben64
Message 6 of 9
(6,746 Views)
Yes. I did try this yesterday.  But in a batch file.  Have to connect to the local net first.  Windows mapping not recognized by command prompt.
The test result was ~ 5 sec in office, and ~20 sec at home.
George Zou
Message 7 of 9
(6,739 Views)
He did mention that ("I can do better with command prompt"), but it's a nice reference anyway! I can imagine most people will simply list all files and then parse the dates, but this must be way more efficient.
Message 8 of 9
(6,735 Views)
Here is my batch file:
PUSHD \\local network path
FORFILES /M *.xlsx /S /D +2017-09-19 /C "cmd /c echo @path @fdate" > %USERPROFILE%\Desktop\list.txt
POPD
George Zou
Message 9 of 9
(6,734 Views)
