Get Row and Column info from an Array Cluster
I have an array with a cluster of 2 elements (string and double). Within my application, I am using the State Machine architecture with an Event Structure. When I click on a element within the cluster array, is there a way to retrieve the row and column? I seen the Coordinates within the Mouse Down event but I don't think that will work.
Any ideas?
(3,101 Views)
Accepted by topic author Eric1977
How To Return the Index of a Mouse-Select Array Element:
https://decibel.ni.com/content/docs/DOC-6406
(3,096 Views)
