Get X Value by using a "drag-able" line on XY Graph
I have a XY graph inside a while loop. I need a vertical line to appear on the X-value where I click on the graph and give me the x-value there. And upon clicking on another place on the graph the line should move there to give and new x-value given out.
(The vertical line is not actually. I just need the x-value depending on where I click on the graph)
I am fairly new to labVIEW and not an expert in using property nodes.
Thanks.
(3,306 Views)
Display the Cursor Legend and Add a cursor.
Create an event for XY Graph Mouse Up.
Create a property node. Set Active Cursor to 0.
Oops, no code capture on this PC. Here's a png.
(3,302 Views)
Thank you. The png helped.
Although, it works only if you drag the cursor now......is there a way to make it work if i just click anywhere on the graph?
(3,293 Views)
Oops, I didn't read your question properly.
You could turn pixels into a scaled x value, move the cursor there (snap-to mode), then read the cursor position again.
Quick and dirty png:
Arg, why won't the image post?
(3,273 Views)
Trying image again.
(3,271 Views)
