control servo motor from from analog input given by force sensor
Hi..i need some advice and guide. i'am very new in this labview field. i have a project to control a servo motor by given analog input from force sensor. i using interface UMI 7764, PCI-7340 controller and NI motion version 7.7.
My project using flexiforce sensor A201 from Teckscan. I have connect that sensor to the analog input slot at interface UMI 7764..i need some idea how to create the programming to control the motor movement when I give certain force at that sensor. I only whan that motor move at certain position after the sensor reach at certain target force.
i hope you can help me.
sincerely
Aminuddin
Message 1 of 1
(2,562 Views)
