need help .
How do i make my waveform look exactly the same as this .? I need to make the green lines similar .
Untitled.pngiiiii
(3,622 Views)
Please provide a more meaningul name for your message subject rather than "need help".  Of course you need help, that is why you are posting the question!
What do you mean by "making the green lines look similar"?  To what?  Each other?
Be clear on what kind of help you are looking for.
(3,615 Views)
okay . attached is my project . i need my temperature waveform to be simliar as the picture . mine is straight lines . as u can see the picture i posted the green line is like curved . every chart have 2 plots . i need the temp plot to be exactly the same as the picture i pasted on my post . the green line .
(3,605 Views)
There is nothing attached.
Since all of your data is faked, then you need to fake the data in a way that makes it look like you want.
Something things you could do is add some signal noise.  You could also do some math that would essentially filter the data or instead of doing step changes in values, you would use interpolation or exponential functions to taper the effect of the change in signal.
(3,598 Views)
would u mind if u  do partly of it and explain to me ? cause i'm stuck . i don't really get what you mean . thanks.
(3,594 Views)
Again with the same question but different topic. Its already been discussed here still if you have any question stick to the same thread and ask questions it would save time for those who try to help you by seeing the history.
(3,586 Views)
alright
(3,583 Views)
