Showing results forĀ
Search instead forĀ
Did you mean:Ā
Get appropriate cell coordinates in List Control while mouse moving
in a List Control of LabVIEW 7.1 I want to show full lenght of truncated entrys via tip strip (like Windows explorer). To this I want to set tip strip by entry of List Control while moving mouse pointer over List Control.
My problem: In Event Case "Mouse Moving" property node provides only XY-coordinates of LV front panel. But I need cell coordinates of List Control who mouse pointer cross over.
Can anybody help? Thanks.
C. Dietz
Christian
Test Engineering
digades GmbH
www.digades.com
Message 1 of 8
(3,975 Views)
Hi C. Dietz,
you can calculate the row by divide the y value by the row height.
Mike
Message 2 of 8
(3,963 Views)
Hi Mike,
thank you for reply.
I tried that already but title of control element and title of columns are unknown dimensions. So I don't know the XY-coordinates from left upper corner of first data cell.
Christian
Christian
Test Engineering
digades GmbH
www.digades.com
Message 3 of 8
(3,957 Views)
Hi Christian,
can you upload an example of what you have done so far?
Mike
Message 4 of 8
(3,955 Views)
Hi Christian,
i think about something like that. i have only a picture in german, sorry for that.
Mike
Message 5 of 8
(3,949 Views)
Hi Mike,
thank you for your activity (keine Entschuldigung für den Anhang in deutsch, damit komme ich sogar besser zurecht Smiley Happy)
This solution works. My initial problem was the unknown offset to first row (see attachement). I hoped this offset can obtain programmatically. Finally I found the offset approximately. It works exactly too.
Christian
Christian
Test Engineering
digades GmbH
www.digades.com
Message 6 of 8
(3,928 Views)
Hi Christian,
to get the height of the caption see the attached picture. I think the height of the column header is the same as all other rows.
Mike
Message Edited by MikeS81 on 04-09-2008 09:17 AM
Message 7 of 8
(3,925 Views)
I'm not sure this exist in LabVIEW 8.5:
Active row position
And another reason to upgrade to LabVIEW 8.x:
Get mouse position
Maybe this will do:
Ton
Message Edited by TonP on 04-09-2008 09:30 AM
My LabVIEW Ideas
Message 8 of 8
(3,916 Views)
