Get character from keyboard
Hi every boby
 i'm going to get character from keyboard. so i use initialize keyboard vi for recognize device and acquaire input data vi for geting that.
this vi is good you can get char even another window is open but there are some problems.
first you can`t seperate small and captal character.
second I couldn`t recognize free state (state that any key pressed).
could you please help me?
thanks
Message 1 of 11
(4,189 Views)
Can you post what you have so far?
Just attach the VI (or VI's if you have subvis) to your message (see Attachments below message body box).
Message 2 of 11
(4,187 Views)
I`m sorry.
Message 3 of 11
(4,172 Views)
Have a look at the attached modified code.
The regular keys appear in: keys
The other buttons appear in: VKey
Or the ScanCode.
Message 4 of 11
(4,149 Views)
thanks but I use LABVIEW ver 11 and it`s not compatible with your file.
Message 5 of 11
(4,132 Views)
Sorry about that.
It's in version 2010.
Message 6 of 11
(4,110 Views)
thank you
but if you run LABVIEW and you open calculator for example, you can`t catch any key exept you click on LABVIEW window again.
i attached an image for more detail.
Message 7 of 11
(4,099 Views)
Oh.. I didn't realize you wanted to sniff the keyboard while another application is running.  I seem to recall something about that, but will have to  search for it.
Message 8 of 11
(4,095 Views)
dear sir. I want add some emergency keys to program and use them in all situation.
do you check sent VI? it`s good VI but it has some weakness.
Message 9 of 11
(4,089 Views)
are there any idea?
Smiley Tongue
Message 10 of 11
(4,050 Views)
