List execution priorities of all VIs in project
Hello all,
I'm using LabVIEW 2012.  Is there any way to list the execution priorities of all the VIs in a project please?
Thank you!
Zola
(2,561 Views)
What do you mean by "execution priorities"?  What is it you are trying to find out?
(2,560 Views)
I've inherited some legacy code. I've been told the execution priority for some of the VIs is set to "realtime". I want to find out which ones.
The execution priority for a VI is set by opening the VI, going to File-> VI Properties and then selecting "Execution" from the pull-down menu. I don't want to have to do this for every single VI in this very big project (there are hundreds). So I wondered if there was some option to list all the VIs and show their execution priorities without having to write code to do it Smiley Happy
(2,558 Views)
I don't see "real-time" on the list of execution priorities, but I do see "high", "time critical", and "subroutine".  I don't know of any easy way to find out that information.  I doubt it exists because I think it would be very rare for anyone to do what you are asking.
That said, I don't think it would be difficult to write a small VI that would loop through your .vi files and read the Execution priority through a property node.  I did the following in about 3 minutes.  You just need to create an array of file names.  Perhaps using directory information to build the list.
(2,549 Views)
