‎12-31-2019 03:59 PM
I'm making a vim to do some array manipulation, and I need to pad it with default values. I feel like I'm overlooking something obvious... but how do you get a default value of an arbitrary wire's datatype?
This isn't my actual application, but say I want a .vim that will create an array with n elements of some datatype, but I want them to be the default value of the datatype. This is what I'm currently using:
A For loop with 0 iterations will just pass the type, not the actual value, so I end up with this, which works:
So this works, but the zero iteration FOR loop feels Rube-Goldberg-esque to me and it's not super apparent at first glance what's going on for someone trying to read my code. Is there a better option?
Solved! Go to Solution.
‎12-31-2019 04:28 PM
I don't have a great answer, but I don't think that many people are around today, so I'll take a shot 🙂
I played around with it for a few minutes and you can use the "Type Specialization Structure" to accomplish it where you have one frame for each data type expected.
That having been said, I actually don't see any problem with what you posted. The Type Spec structure is more verbose, but adding a simple comment to the for loop along the lines of "0 iteration to pass data type not value" would be enough for me to understand what was going on in the code.
‎12-31-2019 07:55 PM
Personally, I find the Diagram Disable Structure to be slightly cleaner than the 0-iteration For Loop.
‎12-31-2019 07:57 PM
Looks all fine to me. A zero iteration FOR loop is a perfectly legal (and sometimes useful) tool. 😄
You could also do something like that.... (Probably very similar code under the hood ;))
‎01-02-2020 03:51 AM - edited ‎01-02-2020 03:52 AM
Why not use the output of a disabled structure? Wire the data type through the disabled case. Leave the enabled case unwired. The data type will be there, the value will be default.
As mentioned.. *SIGH*
‎01-02-2020 05:11 AM
Do the zero-iteration-loop and diagram-disable methods behave the same for child-class objects on parent-class wires? Do they return default child or default parent objects?
‎01-02-2020 05:58 AM
Just tested this to make sure. Both behave exactly the same: You get the default of the exact class that's wired. Wire a child, get a default child. Wire the parent, get a default parent.
‎01-02-2020 07:47 AM
I know Stephen Loftus-Mercer recommends the Diagram Disable Structure method. And it is also used in built-in functions such as the Remove Duplicates From 1D Array.vim.
‎01-02-2020 08:50 AM
Thanks for the replies everyone. I like the DDS better than the FOR loop so I will go with that from now on.
I'd actually looked in a couple of the array manipulation vim's and didn't see a DDS but I must have just missed it.
‎01-03-2020 03:33 AM
I found the opposite, though I might have explained my query badly. Here is an image. I use a parent-class wire, but feed in a child object at run-time. The zero-iteration loop returns a default child-class object, but the Diagram-Disable structure returns a default parent-class object. These two techniques of getting a "default" value are thus not identical for Objects, and one should choose which behaviour one actually wants.
