Get specific data type of numeric control by reference
Is there a property to figure out if a numeric controls data type is e.g U32 or I64? I hand the control to a SubVI by reference.
Actor Framework
Message 1 of 11
(2,899 Views)
Accepted by Quiztus2
There is a property called "Representation" when you enable scripting.
Message 2 of 11
(2,893 Views)
Thanks for suggesting Representation. I can't find this on my properties.
Is there no way without Scripting?
edit: I enabled scripting and now Representation shows up. Thx
Actor Framework
Message 3 of 11
(2,848 Views)
Beware that scripting properties are not available in executables.
Paolo
Message 4 of 11
(2,827 Views)
I have a .ctl containing different Rings and Numerics. I hand this .ctl via it's reference to my SubVI, because the Rings StringsAndValues[] are edited.
If I pass the .ctl via Value those StringsAndValues[] are lost. That is the reason I have to pass by Ref.
So can I cast my reference to my specific control then? If yes, how do I generate a class from my specific .ctl ?
Actor Framework
Message 5 of 11
(2,825 Views)
You can pass your reference as generic Control (as you probably are already doing), use "To More Specific Class" and check whether an error is thrown. But you must try with all possible types.
Edit: if the subvi expects only one type, you must pass a typed reference. To change the reference type, drag a control of desired type into the reference terminal control of the subvi.
Paolo
Message 6 of 11
(2,816 Views)
As simpler way is to use the Get Type Information.vi.
Control reference is a generic Control GObject. Make this into a subVI and wire your control reference to it. You'll get a coercion dot, since it converts to the generic GObject class. However, you'll still get the correct data type.
Message 7 of 11
(2,774 Views)
I believe this one is available in the runtime engine.
Message 8 of 11
(2,755 Views)
You are right. Thanks, I learned something new.
Paolo
Message 9 of 11
(2,724 Views)
If I understand correctly, not all festures of scripting are available in builds. How does one know? What about real time targets?
Actor Framework
Message 10 of 11
(2,654 Views)
