Get step name of currently executing step from post expression tab
I am trying to create a custom step type that records the step name and step results in an array. I have been having trouble trying to access the Step Name property from the post-expressions tab.
One option is to use locals.resultslist[], however, that is only populated once the step executes and hence i cannot access its name through post-expressions. Is there any other property that contains the step name, that may be populated correctly before the post expression  is executed?
(2,706 Views)
I just realized, this has been posted under LabView. Please disregard this, I am putting it under Test Stand.
(2,689 Views)
