GetDate/ format date time string
Hello everyone,
I needed some help figuring why i can't use %p to denote A.M and P.M on my outut screen. When i run the application i get the time but not the denote am/pm.
I've attached both the image and the VI.
(9,094 Views)
Accepted by topic author JÞB
The 12 hour clock used %I for the hour.
The correct format string is %I:%M:%S %p
(9,072 Views)
Use % I instead of %H, %H is for 24h clock.
Ben64
(9,071 Views)
Refer to this forum post for the answer:
http://forums.ni.com/t5/LabVIEW/Using-Format-Date-Time-String-Function-Vi/td-p/1581082
In short, replace the %H with %I to go from 24 hour format to 12-hour format.
(9,069 Views)
Thanks alot!
(9,063 Views)
Thanks alot!
Since i was testing in the morning i never saw anything passed 12 P.M
(9,059 Views)
Have one on me Bill!
Bad format strings can be a pain.  You simply cannot use "H" and expect a "%p" to make any difference!  "%H" denotes a 24hour clock where AM and PM are meaningless  and capitolization is important to format strings.
(9,028 Views)
