Getrows
When using ADO the method getrow return "->value non displayable array"
(3,028 Views)
Do you know what this function is supposed to return? I don't use ADO much, but I was searching around for the function definition to maybe give you some clues. Is this a LabVIEW generated error or from ADO? Does this error occur when you call the function or when you try to place its contents on a front panel control?
J.R. Allen
(3,028 Views)
If you're attempting to create your own database functions and don't wnat to spend the money for NI's database toolkit, I would suggest downloading LabSQL from Jeffrey Travis at http://jeffreytravis.com/
(3,028 Views)
