LabVIEW, close panel (dynamic)
My program uses a sub Vi, which is entered repeatedly without closing the front panel window. (In the vi setup the execution option "show front panel when called" is checked. The option "Close afterwards ..." is not checked.) That works fine. But, before I quit my main program I want to close the front panel of this sub Vi, too. What can I do? Is there any chance to close the panel of a not running vi?
(2,683 Views)
You can use vi.lib\UTILITY\VICTL.LLB\Close Panel.vi. Just pass it the name of the VI whose panel you want to close.
(2,683 Views)
