Getting Error 08 when attempting to build exe using LabVIEW 2009 (32 bit) and Windows 7
Testing development platform on Window 7 vs XP. I received following message while building an executable using 2009 32 bit on Windows 7 machine. Same build will work on an XP machine.
Error 8 occurred at Copy in AB_Engine_Copy_Error_Files.vi->AB_Application.lvclass:Copy_Error_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_EXE.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW:  File permission error. You do not have the correct permissions for the file.
NI-488:  DMA hardware error detected.
C:\Program Files (x86)\National Instruments\Shared\LabVIEW Run-Time\2009\errors\Internet Toolkit-errors.txt
Any suggestions?
(4,204 Views)
Do you have the Administrator access for the PC in that you are trying to build Exe?..
(4,192 Views)
I have administrator access.
(4,179 Views)
Update:  The build path points to a sub directory called APP in the projects folder. I deleted the sub folder then ran the build. The build created the subfolder as I saw it appear in the computer window. At the end of the build the folder was removed. Not sure if this is a default action on a failed build but I believe it shows the permission level to create the folder and files during the build.
(4,175 Views)
For any who may be having this problem here is a little more information and what I did to get around the issue. (so far)
First I tried a simple vi with a while loop in a project and made an executable build. This worked. I double checked on an XP machine the project that I was having problems with. The executable was built successfully. I changed back to the Windows 7 machine.  On the program compatibility trouble shooter I started the LabVIEW 2009 (32 bit) in the XP service pack 2 mode and selected run as administrator. The build was successful.
Note: was logged in as administrator and program would build a simple executable in Windows 7. The executable that would not build had more complex code that included serial communication and calls to lvanlys.dll and nilvaiu.dll.
This may not be a complete fix to the problem but at least in this one case it worked.
(4,150 Views)
I got a hint from another thread.
If you Right-Click Labview and select Run as Administrator it works.
Pressing Shift and Ctrl and clicking Labview is the same thing.
Paul
(4,109 Views)
Thanks Paul for the shortcut suggestion. That will be helpful.
(4,092 Views)
