menu palette file
Hi guys,i created my llb source library and i want to distribute them,putting in userlib folder with the associate mnu file.When i save the palette changes labview modified the dir.mnu(that link to my own mnu file) contains in userlib folder.ok,now i suppose that the user have already his personal palette file mnu under userlib(dir.mnu),how can he do to install my library avoiding to modified her palette ???
(3,308 Views)
Instead of modifying the dir.mnu file create your own independent menu file so that when you install your library you put your own menu file in the user.lib folder.
(3,286 Views)
This are the general rules for user.lib auto palette creation:
  • Everything under user.lib will be placed in an auto created palettes
  • except files that are in a folder or llb start with an underscore (_)
So what I normally do:
  • save my code in a folder starts with an underscore (_mytool)
  • Next to this folder I create an mnu file that contains the relevent VIs that I want to expose via a palette (mytool.mnu), this palette points to the files inside _mytool.
  • I copy both elements (folder and palette file) to user.lib, after a palette refresh (or restart of LabVIEW) your items will be included
So my general setup looks like this:
-built
--mytool.mnu
---_mytool
---foo.vi
---bar.vi
Then in an installer I copy everything in built to user.lib
Ton
My LabVIEW Ideas
(3,264 Views)
