08-28-2020 12:23 PM
LabVIEW NXG 5.0
I have a simple bit of code that reads a tag and writes a new value to it, but it fails on a data type error at the Read Tag Node and Write Tag Node:
"All Notifiers" is a gtype: a cluster containing a "Reference" to a Notifier.
The value of the nodes:
Wire definition, for wire at Probe 1/3:
Wire Definition for wire at Probe 2/4:
The Tag Definition:
And the actual error:
I can't work out why it's an invalid data type. I've done something similar but with Event and Message Queue types - exactly the same setup - and they are fine.
Has anyone got any idea why or how I can debug further?
09-06-2020 09:56 AM
It'll be tough without your read as well.
Why are you using a sequence structure here?
09-06-2020 10:04 AM
I don’t understand what you mean about it being tough?
(and don’t worry about the sequence structure)
