Getting a list of local variables in VI
Hi
Is there any way to get a list of local variables that are being used in my VI ?
Regards
Amit
(3,803 Views)
Hi Amit,
Go to the find function (Ctrl+f), choose Objects radio button, Select object Functions->Structures->Local Variable, choose your vi as search scope and click Find.
//Martin
CLA
https://www.prevas.se/expertis/test--regulatoriska-krav.html
(3,797 Views)
Thanks for the reply,
What i really require is that if it is possible for me to get the list of all the Local variables with their names
and save it into a txt file as we do while looking at the Vi metrics in profile tab?
Regards
Amit
(3,793 Views)
If you have that many Locals that you need a list, you are probably abusing their use.  When overused, Local Variables are notorious for causing race conditions, which leads to unexpected results when executing the code.
If you show us a typical example of your code, we may suggest improvements to avoid Locals.
(3,783 Views)
In addition to what ray has told above.Have a look at this KB article
(3,766 Views)
