The E364Xa configure output VI only does not have a channel selector, but the E3649A PS is dual output. Am I missing something?
Which driver are you using? this one or this one
Did you look at the Dual Channel example? It shows you how to program for the second channel.
(2,654 Views)
Thanks smercurio_fc for your help.  I did have the latest driver installed, however I didn't look through all the sub-pallets and didn't notice that the E364Xa configures the output port seperately from the set o/p voltage.  I just got though using the E363Xa power supply and that one combined those two functions.  I guess I had my blinders on.
(2,622 Views)
