Getting a parity error coming from VISA Read
I am sorry, I am uncertain what you mean by code? Do you mean the program I am using to communicate with it?
 In that case, I will attach it. I am talking in ASCII, as that is what it is currently set on. I could try Modbus, but I don't know how to do that. What is the difference between ASCII and Modbus anyway? There shouldn't be anythign wrong with the program, but if you notice anything, let me know.
I've got a sneaking suspicion that Jesus might have been made of bread. Why else did they have to put him in a warm cave and wait three days for him to rise?
Damnant quadnon intelligunt - They condemn what they do not understand.
Message 21 of 25
(1,017 Views)
Ok. I have gotten the Omega device to work properly in Hyperterminal, but it still doesn't work in Labview. What could be the problem here? Maybe driver issues?
Message 22 of 25
(1,007 Views)
In LabView have you tried enabling the termination character and set it to a carriage return as specified in the Omaga manual
Message 23 of 25
(1,000 Views)
Use portmon to capture the data stream from hyperterminal and save this to a file or screenshot. Then use portmon to watch the labview program execute. Save this to a file or screenshot. Then compare the port setup info and the hex data one byte at a time.
Message 24 of 25
(996 Views)
thank you all. It seems to be working now. I am not totally certain what got it working again, but playing with the baud rate fixed it. I sent it a few commands and it did nothing, then, suddenly one more command and it started right up and is now quite content to give me data... odd, but it works.
Message 25 of 25
(987 Views)
